'41 SC Throttle/Choke linkage
KennyC
07-06-2006 16:44:23
Hey guys. Just got my rebuilt Zenith 9667 carb from FarmerLink.com for my SC. Ran into a dilemma. The carb that was on there before was a Marvel Schebler-
don't ask me what model, I have no idea-and the linkage that goes from the governor arm to the throttle butterfly valve is different than what is supposed to be used with the zenith carb. The butterfly valve "arm" if you will (the piece that mounts to the shaft of the butterfly valve which the linkage pulls on) is threaded, and i need the correct linkage because the one i have is too big and will not thread in. I also need the choke lever that goes from the operators seat to the carb, as that was also different than what was used for the MS carb. Does anyone have a couple of spares lying around they want to part with? I am using an unfolded clothes hanger to run the throttle-which will not allow the governor to operate..... And have to manually set the choke off of the tractor.. Also-What are some good specs to go off of for adjustment of the jets?
Thanks for any input-everyone is always so helpful
C. Amick
07-13-2006 09:08:40
 Re: '41 SC Throttle/Choke linkage in reply to KennyC, 07-06-2006 16:44:23
Might try posting in the classified ads on this web site.
