CASE 930/1030 tach drive
1031D
07-07-2006 21:23:48
I have a 930 and 1030, both late model diesels. I'm trying to fix the guages because nothing works. I put new mechanical temp guages in both of them, and I figures it would be nice to have working tachometers too. Both tractors had the drive cables removed when I bought them, and both tach's are stuck, so I gave them to a friend that rebuilds tach's and speedo's from old cars, and he fixed them up nice. The problem now is the little drive "lug" that sits on top of the oil pump is broken. How does that adapter plug come out? Do I have to remove the oil pump and drive it out?
dboll
07-10-2006 05:02:08
 Re: CASE 930/1030 tach drive in reply to 1031D, 07-07-2006 21:23:48
I&T manual has plans how to build a puller in it
1031D
07-10-2006 20:01:18
 Re: CASE 930/1030 tach drive in reply to dboll, 07-10-2006 05:02:08
????? ? I searched all over in that manual and can't find anything about making a puller.
John Saeli
07-08-2006 12:05:35
The Tach drive will pull out with the proper puller. A slide hammer works good. The problem is making an adapter to thread into the drive.
Roger (Mi)
07-08-2006 18:25:42
 Re: Making a tach drive puller in reply to John Saeli, 07-08-2006 12:05:35
My son and I took the male end from an old tach cable, brazed on a 3/8 stud, screwed it into the tach drive in the block, put a large socket over the drive in the block with the stud sticking through the square drive hole of the socket, put on a washer and 3/8 nut, and turned. Out it comes.
