1930 Case L differential problem
dlp
07-12-2006 13:49:40
There seems to be a lot of play between the bull pinion sprockets & the spur ring gear. This is causing a lot of clearance between the differential side gears. What is the clearance supposed to be? This unit is pretty noisey & this seems to be loose. Thanks in advance
