1070case powershift transmission problem
curt alan
07-20-2006 16:30:18
Help! my case 1070 tractor will not go into gear. when i push in the clutch the engine does not change its rpm like it normally does, I have pulled the tractor back to the house and it is not stuck in gear. I have also lost power stering. Is my hydrolic pump shot? and if so is this hard to fix? any help would be greatly appreciated!
Triplerange
07-21-2006 07:30:53
 Re: 1070case powershift transmission problem in reply to curt alan, 07-20-2006 16:30:18
The first thing you need to do is make sure you have the correct amount of oil in the transmission. After that it could be the pump or something worse.
Eagle Doc
07-20-2006 20:40:22
If your 1070 is one of the earlier ones the torque limiter is probably broken.
