1370 firewall insulation
Eric in IL
07-21-2006 11:04:20
I have a "76 1370 and I am wanting to seal up/insulate the firewall area. I am getting alot of heat off of the engine into the cab now. The factory stuff is all rotted out. Is there an easy way to get the rear portion of the hood off? I would like to know what you all have done to seal up this area and what type materials you used. Thanks to all replies in advance!
casetrader
07-23-2006 04:49:44
 Re: 1370 firewall insulation in reply to Eric in IL, 07-21-2006 11:04:20
realy the best you can do is take the side panels off and if the breather is not in the way go through the top hood i take small pieces of foam like the cab has an start laying it along the sides look at the side of firewalll that is were most heat comes in realy no easy way to get back hood off a lot of heat comes from steering motor i,ve seen guys use expanding foam spray like you use around windows also,
