Case Eagle plow?
Darren
11-15-1999 19:57:15
I just picked up a 2 bottom 3 pt. plow. I was told it is a Case Eagle, how can I tell? When were these plows built, and for which tractors? Any info would be appreciated, thanks.
Wolf
11-16-1999 06:38:38
 Re: Case Eagle plow? in reply to Darren, 11-15-1999 19:57:15
Check for serial/model numbers first. Maybe post a pic for us??? And I'm told that the Eagle Hitch plow is the only plow that will work on the eagle hitch, something about built in sway. Let me guess, you paid around $200 to $250 for it???? Seems to be the going rate.
Darren
11-16-1999 17:30:22
 Re: Re: Case Eagle plow? in reply to Wolf, 11-16-1999 06:38:38
Wolf, Where would I find the serial numbers? I don't have access to a scanner, so I can't do a picture for you. This plow has a spring under where the top link hooks up, running lengthwise like some sort of shock absorber.
Thanks for the help. By the way I had to give five bucks for the plow.
Wolf
11-17-1999 06:29:29
 Re: Re: Re: Case Eagle plow? in reply to Darren, 11-16-1999 17:30:22
Check with a couple others on the board here, but that sounds right. And you STOLE it for 5 bucks!!!!! ! I've been looking for one myself, but I can't justify spending $250. I know where there's one sitting at, not been used for a number of years, but I just gotta get down there to see the guy. He and I have known each other for years, we just don't see each other very often. And only 8 or 9 miles apart.
Larry
11-17-1999 08:51:08
 Re: Re: Re: Re: Case Eagle plow? in reply to Wolf, 11-17-1999 06:29:29
I wish I could get my hands on a Eagle Hitch plow.
