1194 will not run.
Big Dean
08-02-2006 21:42:17
Hi I have a friend that has a Case 1194 it run out of fuel and he has not been able to get it started since. He has follow the instructions for bleeding the air from the fuel system like it says in the service manual. he has try to start it by pulling it with his MF165. He can get it to run by holding a gas soaked rag over the breath intake but as soon as the gas it gone it stops. If it was a Massey Ferguson I would know what to do but I am not familar with the 1194 Case.
Elmer
08-04-2006 09:24:26
 Re: 1194 will not run. in reply to Big Dean , 08-02-2006 21:42:17
They bleed out the same as a 135 Massey. Sometimes it helps to crack the injector lines and wind the engine over to bleed them out to the injector. One thing that can happen to those engines, is the snap ring that holds the drive up in place undere the pump can break. The drive gear is helical and when it falls down it will turn and put the timing out.
