2590 Won't lift
FordTractorMan
08-05-2006 20:41:22
Hi all. My Bro in law has an Case 2590 that he says won't lift the 3 pt. hitch. He told me he was chiseling this spring and when he got to the end of the field to turn, he pulled the lever and the chisel plow wouldn't raise. Got it unhooked and the tractor wouldn't even raise its lift arms. The remotes work fine he says. Is this a problem with a control valve/spool or something else? If you need more info, I'll try to get it. Thanks.
FTM
Texas Case
08-06-2006 13:12:59
 Re: 2590 Won't lift in reply to FordTractorMan, 08-05-2006 20:41:22
If the lever got easier to move check the control cable. They have a plastic clevis at the lever and we have replaced several. It might be more, but this is easy to check just remove the panel around the levers and look. They always break when you pull back on the lever. Tony
