1949, LA - Belt Pulley
Jerald Wyssman
10-03-2006 14:31:37
Has anyone found a source for the 1/2 inch rubber dowels (or a suitable substitute) that go in the belt pulley assembly? I've been using wooden oak dowels, but I have to replace them every couple of years. I use the tractor at several shows during the year running saw mills and threshers.
RobertTX
10-04-2006 10:08:39
 Re: 1949, LA - Belt Pulley in reply to Jerald Wyssman, 10-03-2006 14:31:37
McMaster Carr has the stuff. They call it neoprene wire or rope, you buy it in length and cut it into the pieces you need.
Jerald Wyssman
10-04-2006 13:28:13
 Re: 1949, LA - Belt Pulley in reply to RobertTX, 10-04-2006 10:08:39
Looks like McMaster-Carr has what I need. Thanks for the help.
Case Collector
10-03-2006 19:03:11
I cut high pressure hose into pieces the right length put them in the pulley and drive a wooden dowel into them. I thresh with the tractor and havent had to replace the hose bushings.
