49DO
Rick
11-20-1999 07:35:29
Hi i need some thoughts on this situation. I have a 49 Do that i have rebuilt. I can not get it to start.I brought the engine #1 piston up to top dead center before installing the head. I have adjusted the valves(I sent the head out to nappa and had it checked out.) It has a 90% distributor on it,I did not remove this during the overhaul, so it should not have changed. I have installed all new dist. parts, new matalic core wires, new plugs. I have taken the carberator off a running DC, so i know that it works.It does not seem to be getting gas to the head.( I can pour gas into the plug holes and it will pop) Any thoughts on this will help. Thanks in advance. Rick
Larry
11-20-1999 10:27:46
 Re: 49DO in reply to Rick, 11-20-1999 07:35:29
Are you getting feul to carb?
Rick
11-20-1999 13:12:00
 Re: Re: 49DO in reply to Larry, 11-20-1999 10:27:46
After playing around with every thing again, it turned out to be the pionts gap setting.I finaly got to hear it run. 14 months of rebuilding this tractor, all became worth while today. ITS A HAPPY DAY Rick
gk
11-21-1999 14:20:44
 Re: Re: Re: 49DO in reply to Rick, 11-20-1999 13:12:00
Hi from Caseworld.
Congratulations...Sounds beautiful doesn't it?
gk
www.geocities.com/caseworld/index.html
