970 Case info
Dobbs
11-20-1999 18:09:13
Any info on this line of tractor? Found one that owner says when plowing starting pouring out white smoke, he ended row he was plowing and parked the tractor and hasn't used since. Radiator still full, oil looks clean. Any ideas? think this could be a fuel problem (diesel)/pump ? Any info would be helpful. Thanks
Pat Weepie
11-25-1999 22:59:57
 Re: 970 Case info in reply to Dobbs, 11-20-1999 18:09:13
Dobbs,
My Dad had this problem temporarily when some furnace oil was put in our diesel barrel by a mistake from the fuel man. It didn't hurt the injector pump any though thankfully. Best of luck.
Pat
Ron
11-21-1999 05:48:21
We had the same thing happen. We were pulling a disk and the 970 poured out white smoke all of a sudden and lost power. After loosening each line at the pump; we could tell which cylinder was missing. We removed just one head and found the top half of the piston had shattered. We replaced just the piston and the sleeve and rod bearing. Its running fine last three years.
