VAC hyd.
pioneerman
10-29-2006 13:08:46
My VAC lost hyds., I have replaced the belt pulley gearbox and the pump both. It still won't lift my post hole digger. I do have oil coming to the hight pressure line. Any ideas???
mj
10-31-2006 11:14:40
 Re: VAC hyd. in reply to pioneerman, 10-29-2006 13:08:46
third party image
With the lift handle in 'raise' position and the tractor running in neutral, SLIGHTLY loosen or 'crack' the caps (VTA2665) and VT3036 ONE AT A TIME until you get some fluid leakage. This should bleed the pump. I start with the VT3036 caps since that's usually enough. If not, go back and start with the VTA2665 plugs and finish with the VT3036. Good Luck!
pioneerman
11-03-2006 07:59:08
 Re: VAC hyd. in reply to mj, 10-31-2006 11:14:40
Got it going. Thanks for the help everyone!!!
C. Amick
10-30-2006 09:13:49
Are you sure you got all the air bled out of the the system? With the tractor running, open up the wing nut on the pump bleeder valve and move the control lever to the up position. If you don't get a good stream of oil squirting out, there is still air in the system.
