1951 CASE DC-4 Need Info On 10 Weight Hydraulic Oi
Steve Rossiter
10-30-2006 21:40:09
I can't seem to find what my owner's Manual says I need for my hydraulics. It says it required 10 weight oil. Nobody seems to know anything about this kind of hydraulic oil any more?? Can any of you tell me anything about what kind of oil I can substitute "In these Modern Times". I appreciate your help.
Best regards,
Steve Rossiter
Lewiston, Idaho
Paul f
10-31-2006 07:49:10
 Re: 1951 CASE DC-4 Need Info On 10 Weight Hydrauli in reply to Steve Rossiter, 10-30-2006 21:40:09
If your DC has live PTO there was a change. Originally called for 10 w but later the clutch plates were changed (So if your PTO clutch was ever overhauled it would have the new style). Later clutches called for Type A (Dexron) ATF. I had to overhaul my PTO when I got the tractor and I have used ATF for 5 years now...seem to work fine.
Gene Dotson
10-31-2006 04:25:53
Steve;
You will have good service from any of the available universal hydraulic oils. They are available at any farm supply store such as Tractor Supply of Farm Fleet... Gene
