124 CID VAC Engine
Hobobob74
11-06-2006 13:01:16
How can i tell if this is the engine in my VAC. I think this tractor was put together with a 50 somthing and a 40 somthing, so it may be the 124 BLOCK. Is there any way i can tell.
Joe (Wa)
11-06-2006 14:13:25
 Re: 124 CID VAC Engine in reply to Hobobob74, 11-06-2006 13:01:16
Common casting numbers found on Case built VA series 124 cid engines:
Block VT328A below the dipstick.
Cylinder head VT148 or VT159 on the top of the head outside the valve cover, manifold side if I remember right.
Engine serial # is stamped into the block above the starter. S/n starting with a letter (V or A)are ballpark 40's to 1951, starting with a # (7)are 1950 or later.
Joe
