1956 400 standard
Tuggle
11-08-2006 14:35:46
The gear shifter is lose and moves too much from side to side. It is hard to find the right gear sometimes.
Is there a quick and easy way to fix???
Thanks, Tuggle
Doc Larry
11-08-2006 17:02:17
 Re: 1956 400 standard in reply to Tuggle, 11-08-2006 14:35:46
When I had a similar problem, I found a broken detent spring in the shifting mechanism.
You can check to see if the excess play is in the pin in the shift lever. If it"s not there, you"ll need to pull the transmission cover to get to the forks and rails to see where the problem is.
Larry
