splitting pins for s d and c series and don rod
wilson
11-14-2006 11:11:37
Getting splitting pins mad but buddy who owns lathe and drill presss up here in not feeling so good However they are on the way soon. Any body else wanting splitting pins let me know on this site as will not be ably to make many after this run for a while
Lee Aanderud
11-15-2006 11:40:45
 Re: splitting pins for s d and c series and don in reply to wilson, 11-14-2006 11:11:37
Dumb Question:
What are splitting pins?
Lee
C. Amick
11-17-2006 10:06:36
 Re: splitting pins for s d and c series and don in reply to Lee Aanderud, 11-15-2006 11:40:45
They make clutch replacement easier. You insert the 2 long pins in the bell housing bolt holes (one on each side of the tractor). You can then slide the tractor halves apart and the pins provide stability plus they make things easier to realign when it goes back together.
C. Amick
11-15-2006 09:22:45
Some people have them made to Case specs. and others have them made longer to give you more working room. What length is he cutting them to?
j heitkemper
11-14-2006 13:33:38
how much do you have to have for a set ? ..,,,if not too pricey I may want a set ,,,thanx .,jim
wilson
11-17-2006 10:43:23
 Re: splitting pins for s d and c series and don in reply to j heitkemper, 11-14-2006 13:33:38
I charge 39.00 for either long ones or made to case specs includes shipping Unless you want original case tools i recomend lonfer ones about 18 inches
