14.9-24 tire chains 1965 Case 530ck
scott hallock
11-14-2006 20:08:23
I'm looking for a set of chians for my Case tractor, size 14.9-24 tire chains. Where can I find a set? Does anyone have a set? Also where can I find a manual on this 1965 Case 530c backhoe ? I recantly bought it and blew a hydraulic line. I just got a new line made but not sure where and how much hydraulic fluid to add.Any info. greatly apprecieated. Thanks Scott
CTP
11-15-2006 17:30:27
 Re: 14.9-24 tire chains 1965 Case 530ck in reply to scott hallock, 11-14-2006 20:08:23
Scott, You can try Jones Salvage Classic AG for chains. 800-286-2171. Nice people out of Nebraska. Bought several items from them. Field chains for your tractor will run about $300 for the set. As for the hydraulic fluid, there should be a port on the right side (vertical) reservoir just in front of the loader spool assembly. Mine has a ninety degree NPT fitting with a pipe plug sealing it. I press a funnel into it and fill it until the fluid is level with the fitting. Good luck. Write me if you have more questions. I've had mine '63 for about two years now and have done much work on it. Charlie
scottwv
11-15-2006 05:11:38
If your looking for a new set check out tirechains.com They have good prices, reasonable shipping and quick delivery and the chains are very good quality.
