1370 oil pan removal
c hess
11-16-2006 14:19:06
Question for Jim-dawg-grumpy-rodger or anyone . Do i need to remove all bolts in front axle an jack up tractor or loosen front bolts enough an remove back brace to remove oil pan.
Grumpy
11-17-2006 04:59:14
 Re: 1370 oil pan removal in reply to c hess, 11-16-2006 14:19:06
I found it easier to take front axle out from under tractor and set front casting on good jack stands. You will have more room to work on bottom side of motor. Stan
c hess
11-17-2006 07:31:04
 Re: 1370 oil pan removal in reply to Grumpy, 11-17-2006 04:59:14
Thanks Grumpy. Sometimes i get into more than i thought it would be. Time to get the wooden blocks an tackle it AN KEEP SAFETY IN MIND ALWAYS.
