1948 case D
bcdave
11-20-2006 18:53:38
I am looking to buy a 1948 model D. It has a eagle hitch operated by a single acting cylinder. Is this original. Second, Is a Case model D Positive or negative Ground.
Thanks Dave
Mathias NY
11-21-2006 12:11:36
 Re: 1948 case D in reply to bcdave, 11-20-2006 18:53:38
Are you certain the tractor has an eagle hitch and not just a 2-point lifting bar? Many times this lifting bar (used for raising cultivators) is mistaken for an eagle hitch.
Tom Railsback
11-20-2006 18:57:20
Dave: Eagle Hitch was no available on the DC until 1952. The D series is negative ground.
bcdave
11-20-2006 22:04:25
 Re: 1948 case D in reply to Tom Railsback, 11-20-2006 18:57:20
I took the serial no. off the engine is there an other way to confirm the age.
dave
Tom Railsback
11-21-2006 08:27:55
 Re: 1948 case D in reply to bcdave, 11-20-2006 22:04:25
Based on the serial number, the engine may have been changed.
Look on the right side of the transmission case next to where the the drawbar attaches. there should be a small oval with a casting date in it.
bcdave
11-25-2006 08:38:51
 Re: 1948 case D in reply to Tom Railsback, 11-21-2006 08:27:55
I went back and checked the tractor again and there is a color difference between the engine and the rest of the tractor. I guess the engine has been changed. I'm starting to have second thoughts about this machine.
Thanks for the help
dave
