1030 front end troubles
1031D
12-13-2006 18:23:42
I have a 1968 1030 that I'm rebuilding the front end on because it handles and steers like crap. I'm replacing the front bolster bushings, and the front mount with 2 bushings is egged out. Do you guys have any tips to fix this? If I pressed the new bushings in, they would only contact about 3/4 of the bore.
1031D
12-14-2006 14:55:14
 Re: 1030 front end troubles in reply to 1031D, 12-13-2006 18:23:42
I'm going to weld up the front bushing hole, but I was wondering if anybody knew if the front block on the axle is cast iron or cast steel?
TexasWren
12-14-2006 04:41:30
I've got the same problem on my 830. I'm thinking about taking the front beam to a machine shop, having them ream it oversize and turning my own bushings. It's a great warning system, though -- I can tell when the front end is getting light by the "clunk" as the axle unloads!
Camboted
12-14-2006 05:41:09
 Re: 1030 front end troubles in reply to TexasWren, 12-14-2006 04:41:30
Re-boring is one solutution and inserting an oversize bushing is a good fix, we have welded up the hole and rebored it.
1031D
12-14-2006 07:05:21
 Re: 1030 front end troubles in reply to Camboted, 12-14-2006 05:41:09
well, I just might weld it up and bore it out on my brideport. Where would we be without a good farm shop?
