12 and 6 volt
jerry niles
12-17-2006 19:13:04
I have a 311 case tractor that has been used with a 12 volt battery on a 6volt tractor system. My question is what ignation,such as distributor would be harmed. Also how do you tell if a starter is a 6 or a 12 volt. A
Joe (Wa)
12-17-2006 19:52:18
 Re: 12 and 6 volt in reply to jerry niles, 12-17-2006 19:13:04
Some of the round nose 300's were 12v from the factory, I think all the 300B were factory 12v.
Assuming you have a 12v gen or alt, the only thing 12v on a 6v system will impact is the fuel gauge, coil, and headlights. A 6v coil will live for awhile, if it has a ballast in series it isn't a problem.
The starter will handle either 6v or 12v unless you crank it to death, they are rarely changed out on a 6v to 12v conversion. The round nose 300 6v starter is Autolite MZ4139 (LP) or MZ4176 (gas), 12v starter is Autolite ML4352.
Joe
jerry niles
12-21-2006 14:04:35
 Re: 12 and 6 volt in reply to Joe (Wa), 12-17-2006 19:52:18
Thanks Joe, now i'm looking for a 6 volt starter for a 311b. Not having any luck so far If youknow of one please let me know.
Joe (Wa)
12-21-2006 22:07:57
 Re: 12 and 6 volt in reply to jerry niles, 12-21-2006 14:04:35
I have a 311B also, it is factory 12v. There are no 6v parts listed in the Case parts manual for the 300B series, everything is 12v.
Joe
jerry niles
12-22-2006 14:07:17
 Re: 12 and 6 volt in reply to Joe (Wa), 12-21-2006 22:07:57
THANKS AGAIN, DO YOU KNOW WHERE I COULD FIND A 12 VOLT STARTER FOR THIS TRACTOR. YESTERDAY TRACTOR DID,NT HAVE ONE
JERRY
