CASE 830 TROUBLESHOOTING HYDROLICS
MIKE LANGRAN
11-30-1999 12:19:24
OIL IS COMING OUTSIDE AROUND SEALS WHEN PRESSURE IS APPLIED T0 3 POINT AND HYDROLICS. WHAT CAN I DO ABOUT it?
Larry
11-30-1999 23:37:28
 Re: CASE 830 TROUBLESHOOTING HYDROLICS in reply to MIKE LANGRAN, 11-30-1999 12:19:24
Which seals are you talking about?
rob
11-30-1999 20:00:42
I have a 580ck but hydraulics are hydraulics. Cheapest way to go is pull the cylinder off and take to a reputable hydraulic shop for new seals, honing,and rechroming if required. Honing is reasonable, rechroming expensive. Some safety issues: Move the control lever back and forth to relieve pressure before removing hoses.Make sure to block any attachments before disconnecting hoses.Hydraulic cylinders can weigh a lot, use the proper lifting equipment.Also, get a service manual, available from Case. It will give you details you should have and worth the money.
