1956 400 standard, 2 problems
Tuggle
12-26-2006 19:45:13
Howdy all, On my 400, I need the air intake tube. I tried to make one out of PVC with no luck. Can one from a 700 or 800 work??? Does anyone have one???
Next problem, I lose power in road gear when the governor opens. Seem like when she gets to this point, she only runs on full chock. When I take the chock off, she coughs and stalls. After start, runs fine.
I backed out the power screw on carb, but no difference.
Happy New Year, All
vac400
12-27-2006 07:04:54
 Re: 1956 400 standard, 2 problems in reply to Tuggle, 12-26-2006 19:45:13
Tuggle,
There are a lot of tractor yards that have that part. Were do you live? Call Ed Axthelm 419-864-4959 in Ohio.
On your lose of power , sounds like you have a fuel problem. First I would see if you have a good flow of fuel from the tank. Sometimes the bowl assemble neck gets pluged or the shut off screw. Take it out and clean it. than check the tank for material in it.
Then work your way to the carb.
I hope this helps. Also you may want to check your coil and points . Jerry
JW
12-26-2006 20:02:08
The air intake you need is specific to a 400.You can use one from a 800 but you'll need to use the 800 aircleaner as well for things to line up. Sounds like you need to take your carb off and clean it out good. Most likely a chunk of something in a passage
