1030 generator light
TBA
01-10-2007 19:07:49
On my 1030 when the battery is hooked up and the key is off the generator light comes on and the filter light about half way, Then when the key is turned on gen. light goes off and filter light is on bright like it should. When running all lights are out like they should. The gen.is charging, just had it rebuilt. Any Ideas ? Thanks
1030 brian
01-12-2007 08:58:24
 Re: 1030 generator light in reply to TBA, 01-10-2007 19:07:49
Could be a wire on backwards on your gen or ign switch. Or maybe a short w/ 2 wires touching. Brian
TBA
01-11-2007 18:00:48
I had this problem before fixing the gen., It charges ok now.
Patrick Tercho
01-11-2007 15:38:19
Brian has good advise,and you may want to try re-polarizing the generator/regulator. You said it was just serviced, it might be the problem. Good luck.
1030 brian
01-11-2007 05:42:04
Check your grounds or maybe your ignition switch is bad. It cant be too many things. Good Luck! Brian
