1370 PTO
Ray 1
01-11-2007 07:28:08
The PTO on my 1370 will not engage. Any tips or suggestions before I rip into it
dbock43
01-12-2007 08:15:14
 Re: 1370 PTO in reply to Ray 1, 01-11-2007 07:28:08
Definitely check the control cable before you tear into the PTO. We have had to replace ours twice.
nb
01-12-2007 06:19:52
The pto valve is on the right hand side just ahead of the powershift valve. If the spool is moving, you may want to check the hyd. pressure going back to the clutch.
TomVAC
01-11-2007 18:29:47
Ray, make sure the control cable is moving the valve spool. I can't remember where the valve is but follow the hydraulic lines from pto to the valve.
