1175 3-point
Case400
01-25-2007 20:20:46
We got a 1175 a few years back and have now started geting her fixed up. We have noticed that the 3-point on the tractor is a little jumpy. The tractor will not hold the hitch up when shut off. When running, the hitch does not seem to respond correctly when moving the lever in the cab. Also when running , you put down pressure on the hitch arms with yor hands the hitch will jump up and down an inch or so.
Any idea on what might be causing this? When we first got the tractor my uncle replaced the O-rings on the 3-point cylinder.
Thanks for your time, Case400
DKase
01-27-2007 20:40:40
 Re: 1175 3-point in reply to Case400, 01-25-2007 20:20:46
My 930 did the same thing last spring. I found the lowering valve in the DOM valve stuck open. DK
case trader
01-27-2007 07:16:26
jumpy indicates oil is leaking an probably the 3-point cyl. o-ring it fixed mine but does seem odd since you say it was replaced recently
