slow lift responce
1070 troubled
01-28-2007 18:51:51
I have tryed to fix my tractor but I aint doing so well. I noticed slow responce on my lifting arms and on the front lift. i relpaced the pump and filters out big cash no fix so i took the tank off and looked at the remote valves not stuck could it be in the divider valve on the side of the tractor.
1070 troubled
01-29-2007 16:43:10
 Re: slow lift responce in reply to 1070 troubled, 01-28-2007 18:51:51
I put fuel in started it lift improved. now it leaks at the rigth end of valve. 1 after the other. thanks dwag
dwag
01-29-2007 17:14:01
 Re: slow lift responce in reply to 1070 troubled, 01-29-2007 16:43:10
Switch from F.S. to Mobil fuel and leak will dry up.
dwag
01-28-2007 20:10:48
Remove relief valve(big plug at center of remote valve) and check, especially the o-ring below poppet assy. part # A17526.
1070 troubled
01-29-2007 06:25:54
 Re: slow lift responce in reply to dwag, 01-28-2007 20:10:48
I checked it the o ring was ok it came apart easy went together same way no trash i could see it lifts so slow now i have to rev the engine to lift hay tranny shift good turns good too filters had lot of metal when i changed them. relief had 2 shims under spring. simple system i wander if spliter valve is stuck not sharing enough to work right
dwag
01-29-2007 10:35:24
 Re: slow lift responce in reply to 1070 troubled, 01-29-2007 06:25:54
You need to plug a guage into remote coupler and read press., should get around 2000#. If tractor is a powershift, try raising hitch in different RPS ranges to check for internal leak in powershift. I doubt problem is in flow divider valve. Flow check pump to check for a plugged suction screen.Are hyd"s noisy?
