1948 Case DI
dittmerku
02-04-2007 04:31:47
good morning, I just bought a case DI to restore. Is the manual for a D pretty much the same? I figure there will be some differences, but for the most part will the parts manual and the I&T manual for a D work? Also, anyone know where to get used parts for one? The front spindle/axle is cracked and has been poorly welded. I doubt it will work. This is my first Case. It has a huge loader on it too. I have restored a ford NAA already so I'm not completely new to this. Thanks, Kurt
Brian in Ohio
02-04-2007 04:51:52
 Re: 1948 Case DI in reply to dittmerku, 02-04-2007 04:31:47
Yes, the manuals and I&T books for the D will work for the DI. There are some slight differences between the two tractors, but internally, they are the same.
As far as parts go, I'd start with Don Livingston, who hangs out on this board. Just post a message for him with your needs, and he'll get with you. If you are near a Case dealership that has been open a long time, you might have good luck finding D parts through them.
dittmerku
02-04-2007 07:28:50
 Re: 1948 Case DI in reply to Brian in Ohio, 02-04-2007 04:51:52
Thanks Brian. Knowing the manuals are the same will be a big help. Kurt
