David Brown 990 - front lift and lift arms doesn't
Marcin
02-21-2007 13:01:40
I have David Brown 990. Three weeks ago I have bought front loader for this tractor and mouted it. Everything was working fine for one week and sudennly it stopt lifting front loader and three point hitch! hydraulics NOT working. There is oil in the gear box. What can be the problem?
tom stanley
02-21-2007 14:00:19
 Re: David Brown 990 - front lift and lift arms doe in reply to Marcin, 02-21-2007 13:01:40
have seen the coupler on the rear pump shear the retaining pin and this lets the pump drive slid apart to git to this remove pto you dont have water in hyd do you? if it gets in there it can freeze over screen and give same affect if this is problem check gator's on shift levers this in the USA we call boots hope this helps tom
