18.4 x 30 tires will they fit ??
Mark in Iowa
03-11-2007 14:54:03
I was wondering if the rims and tires [ 18.4 x 30 ] off of a MM-U would fit on a Case La ?? I know the tires will , not sure if the rims will ... THANKS for any and ALL advice...Mark
ACEd(La)
03-11-2007 15:47:29
 Re: 18.4 x 30 tires will they fit ?? in reply to Mark in Iowa, 03-11-2007 14:54:03
Assuming you now have 30 inch on the LA look at interface wheel center to rim. There are 2 or 3 common interfaces - one has single raised hump about an inch high - other common (more modern) design has 2 smaller raised areas. I think you will find the MM are the single hump variety as well as the Case, but best to measure dia at smallest point. I thought the LA's had 34", but I'm mostly AC & MM so don't know for sure. As I recall there are also some anti-rotation stops which you should be able to confirm with eyeball and measuring tape.
AllanC
03-11-2007 22:03:57
 Re: 18.4 x 30 tires will they fit ?? in reply to ACEd(La), 03-11-2007 15:47:29
I Think ACEd has good advice on the rims. As for tire sizes LA's came with 14 X 30 as standard, 15 X 30 optional. These are replaced now with 16.9 X 30 for the 14" 18.4 X 30 for the 15 ".
Bob from Australia
03-11-2007 16:26:44
I have 18.4 x 30 tires on a 1944 LA. Not much clearance between tire and fender.
The other (1949) LA has 16.9 x 30. It has plenty of clearance.
