1951 DC rod knocking?
Barry Small
03-16-2007 14:09:05
During the recent ice storm here in Missouri I had to really work my old DC,chaining and dragging downed tree's and pulling down dead falls etc. My hearing is pretty sorry, but I think there is a knock down low about the top of the pan and back about number two or three cylinder. That says rod to me, and I don't recall anything like this before. At first I thought it was a vibration when idling since I had chains and tools hanging all over the old girl,but that wasn't it. I don't hear it when the rpm's are up. What do you think? What can I do? Thanks
Barry Small
03-16-2007 22:05:04
 Re: 1951 DC rod knocking? in reply to Barry Small, 03-16-2007 14:09:05
Thanks for all your advice and suggestions, I'll let you know how it turns out.
wilson
03-16-2007 19:43:35
don't fprget you can replace rod and piston from bottom!!! no need to pull head
Walt Davies
03-16-2007 15:19:22
It could be a piston also. Removed a spark plug to determine which one it is. The noise will either get louder or go away (darn if I can remember which is which) but one way its a rod the other its the piston. Boy old age must be catching up on me.
Walt
Nedd
03-16-2007 14:26:05
Better be sure. Drain oil and pull a side plates. Check the rod caps, check journals and remove the shims on caps if journals are okay. Babbot is forgiving and you might get lucky. Good luck
dctom
03-16-2007 14:19:12
TAKE HAND HOLE COVERS OFF AND CHECK ROD BEARINGS TAKE SHIMS OUT IF YOU THINK THEY ARE LOOSE
(ps the way i do it i take shims out till icant turn engine than but one or two back in for proper clearance) tom
J Heitkemper
03-16-2007 19:00:36
 Re: 1951 DC rod knocking? in reply to dctom, 03-16-2007 14:19:12
Agree to check those Rod Bearings!! Let us know what the problem is , And What you found , Sadly 10 years back,, while bush hogging some saplings I lost a Good DC motor when a snag or sharp object nicked the oil pressure line and she literally bled to death , I kick myself for not noticing the small leak ,,. Friend of mine had a Nice 285 Massey , While chopping corn stalks late at nite , the oil filter was nicked ,, And She too ,bled too death I hope that You caught Her In Time ,, Best wishes ,, Jim
