2590 Trans. Locked
DSMia
03-20-2007 19:11:53
What might be the cause of my 2590 being locked in 2nd gear? Powershift works fine forward and reverse and it is not a linkage problem, simply stuck in 2nd and will not come out. Thanks.
DSMia
03-21-2007 11:14:27
 Re: 2590 Trans. Locked in reply to DSMia, 03-20-2007 19:11:53
Is this accessed by removing shaft cover on right side of tranny housing? Thanks.
dwag
03-21-2007 18:35:28
 Re: 2590 Trans. Locked in reply to DSMia, 03-21-2007 11:14:27
Yes, after unhooking shift linkage. You"ll need to drain trans/hyd oil also.
dwag
03-21-2007 10:39:55
1 Thrust washer between gear and collar hub may be damaged(egg shaped) and blocking splines on shift hub and collar. After getting out of gear(any way you can) cut/pull/pry/dig washer out and discard. Go ahead and use tractor.
2 Shift rail must not have any movement. If rail moves, 5/16 retaining bolt is loose or broken. If loose, a wrench can be bent to reach in to tighten. If bolt is broken, tractor must be split.
