148 gas smoking
Farmer76
03-27-2007 05:13:52
I recently put a new head gasket on a 148 motor and now it is smoking. Is the head gasket leaking? Or just terrible luck and now something else is wrong? It was not smoking before. As always any help is appreciated.
kingmondo
03-28-2007 18:35:44
 Re: 148 gas smoking in reply to Farmer76, 03-27-2007 05:13:52
is the oil level in the crankcase way too high.
BCnT
03-27-2007 16:38:29
did you grind the valves while you had head off??? wouldnt be the first time i've seen fresh lapped valves suck oil past old rings.
Roger in Iowa
03-27-2007 06:35:54
What color is the smoke? Blue= oil, black=to much fuel or not enough air, white=water or if it is a diesel= bad injector or low compression.
Roger in Iowa
kingmondo
03-27-2007 05:44:54
Are your spark plugs getting fouled or is water getting in your oil pan?
