1370 steering
brandonsundeen
04-03-2007 19:08:58
I have a 1370 case. It is hard to steer replaced the hand pump and checked steering rams. Also made sure that the spindles were not seized. Checked the steering relief pressure it is 2200. Has anyone else ran into this?
turbo
04-03-2007 19:26:11
 Re: 1370 steering in reply to brandonsundeen, 04-03-2007 19:08:58
Make sure the needle bearings in the steering column are OK. They can cause extra effort even before the hand pump. Try lubing them with penetrating oil by prying lip of seal back where the steering column telescopes.
brandonsundeen
04-04-2007 17:53:21
 Re: 1370 steering in reply to turbo, 04-03-2007 19:26:11
turns out that the left hand inner tie rod end was loose and trying to carve through the left hand steering ram. All is well now. I also did lube the steering column and that also made a big difference.
