David Brown 25D
charlesmacleod
04-10-2007 01:49:21
Strange problem with this diesel engine , started to sound a bit sick so changed all filters and fitted new injectors , no change in fact getting worse , now only starts with ether , runs very roughly , very smokey and sick. plenty of fuel at injectors , doesn't make any difference if you slacken any particular injector pipe , plenty of fuel at every stage of the bleeding process . The pump looks very hard to remove , seems to need the timing cover etc removed is this the next step ? does anyone have any ideas, the only thing I did not check , now I'm sitting here was the return line to the tank . but could that cause such a problem? many thanks in advance
