1070 Turbo?
chrisk1500
04-11-2007 12:18:07
I was wondering if I could put a turbo on a case 1070 with the 451BD?
What parts would I need off of a 451BDT to make this work? I assume: turbo, intake manifold, and exhaust manifold....what else?
JoeBob/IN
04-12-2007 09:12:58
 Re: 1070 Turbo? in reply to chrisk1500, 04-11-2007 12:18:07
If you are only wanting to add 15 horse I would think you could just turn the pump up some.
chrisk1500
04-12-2007 14:26:15
 Re: 1070 Turbo? in reply to JoeBob/IN, 04-12-2007 09:12:58
Where is the adjustment screw on the IP?
chrisk1500
04-12-2007 14:27:56
 Re: 1070 Turbo? in reply to chrisk1500, 04-12-2007 14:26:15
EDIT - I know that once I put on a turbo I will need to turn up the fuel as well....otherwise the turbo isn't doing anything...
JoeBob/IN
04-12-2007 15:23:13
 Re: 1070 Turbo? in reply to chrisk1500, 04-12-2007 14:27:56
Mostly correct you are and the smoke screw is probably under a sealed cap or a bolt that is somehow sealed to let Case know if it has been tampered with. Seems like it is on the back (towards the cab) of the pump. I know there is also a surge screw located there so I would have to look at one of ours and in a manual.
case trader
04-12-2007 04:32:38
i took mine off my 970 i run it a couple years on hay equipt. no problems but when i put the plow on could'nt keep the pyrometer cool enough an scored pistons {no piston coolers an quality of pistons} but the rest of tractor no problems i feel like if you are trying to get 15 to 20 more hp shouldn't have any problems remember if your engine is wore out this will multiply your trouble.
chrisk1500
04-12-2007 06:32:17
 Re: 1070 Turbo? in reply to case trader, 04-12-2007 04:32:38
The tractor is getting a full rebuild this spring (9000 hours) I was thinking that adding a turbo would help me get closer to the power output of a 1270...
On that note - should I order the BDT kit to get the turbo pistons? Are they coated differently than the BD pistons?
Dairy Farmer in WI
04-11-2007 18:18:41
i think sometimes you need to put a different/ heavier rear-end in but i think you will be fine with that. all depends how much HP the tractor puts out. just my 2 cents
DF in WI
chrisk1500
04-11-2007 18:38:13
 Re: 1070 Turbo? in reply to Dairy Farmer in WI, 04-11-2007 18:18:41
I am just looking for a few extra HP....nothing huge - maybe bump it up from 105 to around 110-115....
Dairy Farmer in WI
04-12-2007 18:43:00
 Re: 1070 Turbo? in reply to chrisk1500, 04-11-2007 18:38:13
you should be fine then unless you went up to 125 or so
just my 2 cents
DF in WI
case trader
04-11-2007 14:11:52
i have one from a 970 401bd should have everything needed
Jeff From WI.
04-12-2007 06:52:26
 Re: 1070 Turbo? in reply to case trader, 04-11-2007 14:11:52
How much are you asking for your turbo equipment? thanks Jeff.
chrisk1500
04-11-2007 17:41:16
Thanks for the offer but I am not looking for parts, I just want to know what parts I will need.
