1070 trans fluid leaking into crankcase
chrisk1500
04-12-2007 10:44:26
I have another question about my 1070. It appears as though my transhydraulic fluid is leaking into my engine's crankcase (fluid level in the trans drops and the crankcase oil level rises). Where are the two systems in contact with each other that might cause this problem?
Thanks
dwag
04-13-2007 20:37:30
 Re: 1070 trans fluid leaking into crankcase in reply to chrisk1500, 04-12-2007 10:44:26
Rear main seal. Saw this once on a 2670, rear seal was letting trans oil into crancase.
chrisk1500
04-14-2007 06:22:45
 Re: 1070 trans fluid leaking into crankcase in reply to dwag, 04-13-2007 20:37:30
I guess I have to split the tractor then?
dwag
04-14-2007 06:58:26
 Re: 1070 trans fluid leaking into crankcase in reply to chrisk1500, 04-14-2007 06:22:45
As Sylvester would say... Yethhhh
chrisk1500
04-14-2007 13:49:36
 Re: 1070 trans fluid leaking into crankcase in reply to dwag, 04-14-2007 06:58:26
Thanks....sounds like a fun spring project *sarcasm*...
