148 cyl sleeve
Jim Wilke
04-13-2007 18:40:11
Hi All,
I have a 148 in a "57 320 loader that has one piston stuck at the bottom of the stroke. I have soaked it for a year but it does not want to move. I took off the rod cap & put a bar up inside the piston & jacked up until the front of the loader came off the ground but the piston & liner did not come up out of the block. This IS a wet liner, right? Other than busting a hole in the piston to rig a puller from the top does anyone have a good idea how to get the liner & piston out of the block?
Jim Wilke
04-14-2007 06:17:25
 Re: 148 cyl sleeve in reply to Jim Wilke, 04-13-2007 18:40:11
Thanks Tim,
But the 148 IS a wet liner, right? I just don't want to be beating the tar out of it if the liner is pressed in.
I can't get anything much but a solid 3/4 bar up inside the piston because the crank & rod are in the way. She stuck when the crank was at dead center on the bottom so I can't rotate the crank to the side. I did remove the bearing shell so that gave me a little room to try to move the piston down. But I thought if I could push the piston up with the liner, I could take it to a shop & have the piston pressed down & out.
TimBinWV
04-14-2007 13:14:59
 Re: 148 cyl sleeve in reply to Jim Wilke, 04-14-2007 06:17:25
Put up pressure on the piston,then heat the liner with a torch. Not all in one spot,but evenly,all over.Don't get it hot enough to melt anything,just nice and hot. After getting it hot,squirt wd40 around the piston.
jim wilke
04-14-2007 15:38:45
 Re: 148 cyl sleeve in reply to TimBinWV, 04-14-2007 13:14:59
Thanks Tim,
I hadn't thought about that but it should slightly expand the liner & with luck make the piston pop loose.
I'm going to hone out all the crud I can reach first so if it does start to move it won't go far before it should go easier. From the other pistons I see that the water didn't get past the rings, not like some real bad ones where the whole piston is corroded.
TimBinWV
04-13-2007 19:04:02
Try putting the "up" pressure on the piston,then rig some blocks of wood on top of the block,then driving down with a sledge.You may want to drive down on the sleeve that's stuck. You may try a piece of wood (oak) cut to fit inside the piston from underneath and drive it upward with a sledge,too. Good Luck.
