211b starter
Joe in pa.
04-16-2007 09:00:16
I'm looking for a starter for a 211b. used would be ok thanks for any help
C. Amick
04-18-2007 09:19:41
 Re: 211b starter in reply to Joe in pa., 04-16-2007 09:00:16
I did some research. It looks like the Case 200 and 300 Series tractor starters are the same. A rebuilt one is $134.00 in the catalog that I have. Email me if you want the phone number.
BarryfromIA
04-17-2007 18:34:14
I have a 210-b-h and will look at the numbers on the starter, if I can remember before dark. Might look Wednesday. I had it rebuilt at Torco in Dakota City in Nebraska about 5 years ago. Maybe they have a rebuilt for sale.
BarryfromIA
04-18-2007 18:22:38
 Re: 211b starter in reply to BarryfromIA, 04-17-2007 18:34:14
Checked my starter tonight, it reads as follows auto-lite m/ 4176 3p. These tractors were built with 6 volt systems. I changed to a 12v alternator because it is cheaper and more reliable and charges faster on the short runs I use it for. If you by a rebuilt ask for the heavy duty bendix drive. This starter is different than the one on my 311b. I wanted a quick fix when the 210 starter broke by inter changing them, but it was a no go the pinions are different diameter. The 311b has a larger diameter flywheel.
C. Amick
04-16-2007 09:11:57
Have you checked with anyone? I'm thinking that a Case VAC starter may work on your tractor? There are a lot of those lying around.
