CASE 1150 OIL HEAT EXCHANGER
MIKE BLAKE
04-23-2007 07:16:32
I HAVE AN 1150 SERIAL 7109126. I CANNOT FIND AN OIL HEAT EXCHANGER AND CASE HAS DISCONTINUED THIS PART. IF ANYONE CAN GIVE ME A LEAD I WOULD APPRECIATE IT. MIKE
Roger (Mi)
04-24-2007 18:04:44
 Re: CASE 1150 OIL HEAT EXCHANGER in reply to MIKE BLAKE, 04-23-2007 07:16:32
Might try Cook Equipment in Allegan, Michigan. They have lots of Case dozers in their salvage yard. Not sure of area code (269 or 616) 673-5454. I have a 1150 dozer too. It started pumping oil into the cooling system. I ground an oil passage throught the base, then sandwiched an aluminum plate between the base and oil cooler. Use 20W-50 oil and have no problems.
