1955 CASE VAC
D OLMSTED
04-24-2007 15:28:14
I am searching to find out if this Case tractor has a positive or negative ground. I have been told during these years they were both ways. How can I determine which ground to use for this tractor.
Martini
04-25-2007 08:27:10
 Re: 1955 CASE VAC in reply to D OLMSTED, 04-24-2007 15:28:14
If there is still the original generator installed look at the coil to distributor wires.
+ coil post to distributor is a positive ground,
and - coil post to distributor for negative
ground. If you have an alternater installed,
all are negative ground unless custom built.
charley hellickson
04-24-2007 19:40:22
Hi. That Racine on there just means the company headquarters. The VAC was made at the Rock Island plant. The SC and bigger were made at the Racine plant. Charley.
D Olmsted
04-25-2007 18:10:55
 Re: 1955 CASE VAC in reply to charley hellickson, 04-24-2007 19:40:22
Thank you for all the information. It was very helpful.
Jim - Oregon
04-24-2007 18:28:50
If your VAC serial number starts with "55" it is a 1951 year model not a 1955.
Gene Dotson
04-24-2007 15:42:52
VAC uses positive ground. All tractors made at Rock Island had positive ground systems and all tractors made in Racine used negative ground... Gene
D OLMSTED
04-24-2007 17:14:51
 Re: 1955 CASE VAC in reply to Gene Dotson, 04-24-2007 15:42:52
Name tag on tractor where the gauges, amp meter, oil pressure, light switch, etc. stamped says CASE
VAC5558089
Racine, WI
The reply confuses me a bit. You say VAC are all positive ground, but then Rock Island are Positive and Racine are Negative. Is that for CASE in general. I assume you mean since it says VAC it is positive ground. We just had the generator rebuilt and want to make sure we hook it up the ground correctly. Thank you for all the information.
