530 case no start
MAH
04-28-2007 14:25:10
Trying to start diesel that sat for 5 years. I cleaned fuel tank out and put new fuel in.Changed fuel filters. Fuel gets to pump but won,t go past. I would like to remove pump to clean. I have removed lines and bolts from pump but it won,t slide out. what do I do next
Roger (Mi)
04-28-2007 18:27:06
 Are you trained for injection pump repair? in reply to MAH, 04-28-2007 14:25:10
The filter bracket needs to be removed to allow the fuel injection pump the necessary room to come off of the pump drive shaft. Clean the pump? It's STRONGLY recommended that you take the pump to a diesel injection pump service center! They have the extremely clean working environment and the knowledge to fix it right. Make sure to align the timing marks in the fuel injection pump (small plate on the side of the pump) before removing the pump.
