1957 Case 401 Super Diesel
Jim from Calif
05-03-2007 14:47:11
Does anyone know the number of '57 Case 401 Super Diesels made? (Both row-crops and wheatland's) or A contact who may have the old J.I. Case records
rgorange
05-03-2007 15:56:45
 Re: 1957 Case 401 Super Diesel in reply to Jim from Calif, 05-03-2007 14:47:11
According to 'Illustrated Buyer's Guide Case Tractors' Second Edition by Peter Letourneau, for the 400 Series in 1957 there were: Qty ----- Type
-445 400 Standard/Dsl
1823 401 GP/Dsl
----0 402 Hi-Clear/Dsl
---25 403 Hi-Clear/Dsl
----0 405 Orchard/Dsl
---70 420 Industrial/Dsl
rgorange
05-03-2007 16:03:05
 Re: 1957 Case 401 Super Diesel in reply to rgorange, 05-03-2007 15:56:45
That sure didn't come out formatted like I typed it and previewed it! No tables displayed here! Let's try again. I listed those with a quantity of 0 because there really was such a model... just none built in 1957.
According to 'Illustrated Buyer's Guide Case Tractors' Second Edition by Peter Letourneau, in 1957 there were: 445 Model 400 Standard/Dsl, 1823 Model 401 GP/Dsl, 0 Model 402 Hi-Clear/Dsl, 25 Model 403 Hi-Clear/Dsl, 0 Model 405 Orchard/Dsl, 70 Model 420 Industrial/Dsl
Jim from Calif
05-03-2007 18:37:39
 Re: 1957 Case 401 Super Diesel in reply to rgorange, 05-03-2007 16:03:05
I don't understand. My research shows all Case 400 Diesel's with a serial number greater than 8106131 were Super diesels.
A few parameters which made them different then the earlier 400 diesels were:
1. The engine were 267 cu-in vs 251 cu-in
2. The part number on the Engine block was A111 vs 6400
3. The super's RPMs as depicted on the American Bosh injection pump is 1550, a regular 400 is 1450 4. A 400 super has a latch to lock the pto in the off position -- not true on a regular 400
5. The Super carried the "SUPER" decals
cloydone
05-03-2007 19:20:51
 Re: 1957 Case 401 Super Diesel in reply to Jim from Calif, 05-03-2007 18:37:39
the supers had pressure cooling also-----
rgorange
05-03-2007 19:13:31
The book mentions the details you posted (also says hp increased 6%). It says the "Super 400" was introduced in 1957, but it does not say if ALL of the 1957 models were "Super 400". I doubt it because it says they were both offered. The numbers they provide have them all lumped together. Guess we have to wait for some of the experts to chime in... can't count on the book. Super 400 also had pressurized cooling system, a drag brake on the PTO, larger tool box, and larger tires,
Super Confused
05-03-2007 19:46:07
 Re: 1957 Case 401 Super Diesel in reply to rgorange, 05-03-2007 19:13:31
When you say both were offered, do you mean both sizes of diesels or both gas and diesel? Only the diesels were super diesels, right? Also, was the regular 400 diesel built until replaced by the 400 super diesels? Meaning they were both offered the same year, but not at the same time?
rgorange
05-04-2007 04:29:57
 Re: 1957 Case 401 Super Diesel in reply to Super Confused, 05-03-2007 19:46:07
I don't know the answers myself. The book 'Illustrated Buyer's Guide Case Tractors' Second Edition says "The same blocks were used for both gas and diesel engines". Next paragraph "In 1957 Case increased displacement of the 400 engine to 267ci, spawning a new model it dubbed the 'Super 400'. The Super 400's engine offered a 6 percent boost in horsepower over the engine of what then became the 'Standard 400'. The new model, which was offered in addition to the old model, also added a pressurized cooling system; a drag brake that prevented creeping of the PTO shaft, thereby preventing 'free wheeling' of PTO machines in transport; larger toolbox, and larger tires."
