att . Jeff in ri
J heitkemper
05-11-2007 20:28:48
Get an I T book for the Case O matic. There is a valve stuck or something ,, There are a lot of experienced minds on this forum who are probably busy in the field this time of year ,, So try back later after planting season , Unless you suspect the tranny to be plum shot and worn out from overuse and abuse , The case-o matic is nearly bullet proof .. Best wishes , Jim
charles hess
05-12-2007 09:21:06
 Re: att . Jeff in ri in reply to J heitkemper , 05-11-2007 20:28:48
Jef, I looked in parts on case for 540c an it is not listed. Dont remember that no eighter .Is that correct tractor no? Any way if you can check with a other pressure gage for exact pressure as i have replaced new avaible Case gage on my 830 an green marking is at higher pressure than origional gage giving impresion that it is low when it is not. Also remember with Case-o matic in high range you have to have pretty high rpm to get tractor moving.Have you had tractor long time to be familiar?
