Evacuating hydraulic fluid from Uniloader 1737
MI-Case
05-25-2007 14:08:28
This is a winner-
The hydraulic fluid for the unit is supposed to be ATF, but I've got a whole system full of tractor hydraulic. Anybody have a process or suggestions on the most efficient way to drain out 15 gallons?
Likely part of my drive problems as well - hydraulic fluid screwing with the clutchs.
Thanks
Steve
Walt Davies
05-27-2007 08:49:43
 Re: Evacuating hydraulic fluid from Uniloader 1737 in reply to MI-Case, 05-25-2007 14:08:28
Short of dismantling the whole thing there really isn't anyway to get it all out. Just drain everything that you can and then refill run a while work everything and look at the oil if still a lot of hydraulic oil in it then do it over till you get it where you can live with it.
Walt
