1030 available
nutcase
05-26-2007 19:30:36
I have but one Case an 830 COM Diesel that my uncle purchased new and I like it. I found a real nice 1030 with straght orig cab going on auction close to me here in Indana at a large (452 tractor ) auction in June. Would I be as happy with the 1030 as my 830 ? Would it pull 6 bottoms in sand ok ?
560farm
06-01-2007 18:19:16
 Re: 1030 available in reply to nutcase, 05-26-2007 19:30:36
I got Aummanns flyer the other day. The tractor does look good and the cabs mounts and sits between the fenders for easy removal. Remember the "67 models had a transmission oil cooler added, noticable in a left side view picture, because it runs down along the oil pan, a definite plus if your going to work ground with it a lot. That one will probably bring the $4-4500 for the conditon and the amount of collectors that will be at the sale. Like Glenn said 1030"s had a tendency to overheat and a good 930 would outpull a 1030, do not try and turn up the HP. Stick to a 5x16"s and you can plow the way you want.
GEOMO
05-29-2007 04:39:45
PLEASE LET ME KNOW IF YOU BUY IT AND WHAT IT SOLD FOR.
I CLOSE TO ME, HE WANTS $4,000. A LITTLE MORE THAN I WANT TO GIVE.
nutcase
05-29-2007 17:46:44
 Re: 1030 available in reply to GEOMO, 05-29-2007 04:39:45
do you mind looking at the website and tell me what you think of it ? It runs as good as it looks ,starts right up very clean ,steers nice, shifts good, 3 pt is fast etc
Lamont
05-29-2007 02:37:43
When and where is the auction? Can we view a sale bill online?
nutcase
05-29-2007 17:44:38
 Re: 1030 available in reply to Lamont, 05-29-2007 02:37:43
yes the auction is in June aumannauctions.com look on schrock estate
jim handke
05-27-2007 19:38:56
Yes, you"ll like it as well. It would pull 5 sixteens in fourth gear here in N.E. Kansas red clay hills.
Glenn F.
05-27-2007 04:05:11
Sand is the operative term. Up here we'd pull 4-14's in our heavy soil, but in light sand I'm sure you could pull 6. You may need some front-end weight and rear fluid, especially if you only have 34" tires. Very good tractors. Don't let it overheat.
Glenn
jcmarleau
05-26-2007 21:10:32
One of the best tractor Case ever built. jc.
