Broken hydro filter DC
J heitkemper
05-27-2007 04:06:38
The silver dollar cross key coupler fell out of theDC hydro pump ,, The filter was broke in two , , What would cause that to Occur ,, I puta washer behind the chain shaft to take uop end play for cross key .. Just wondering ,, Jim
bradley martin
05-29-2007 05:59:10
 Re: Broken hydro filter DC in reply to J heitkemper , 05-27-2007 04:06:38
If you had that much water in the hydraulic resevoir and system you likely have much more serious problems.
bradley martin
05-28-2007 18:35:19
Is it possible that the cross coupler struck the filter when it was ejected from its position in the drive? Otherwise, maybe the filter was damaged when it was being installed as those wound paper filters are very brittle. Just a guess.
J heitkemper
05-28-2007 20:08:21
 Re: Broken hydro filter DC in reply to bradley martin, 05-28-2007 18:35:19
uhhh Thanx ,, but Not Likely ,, My guessis that water and condensation in the hydro reservoir is the culprit ,, Anyone else ? Jim
J heitkemper
05-28-2007 20:08:06
J heitkemper
05-28-2007 20:07:45
