2290 Power shift
Joe Prince
05-27-2007 20:04:16
My 2290 I re worked the power shift last year, this winter feeding cattle with it the unite went out. The c3 hub and the big ring gear were burned up. I replaced the parts and have about $3500 in parts some used. When I put the tractor back together I keep power on the C3 test port,C1,C2, C4 are OK. I have looked at the valve and have not found a problem. when you look at the IPC brake down could one of you enplane to me what shifts inside the unite to block off C3. I know in 2 & 3 C3 needs pressure. Thanks Joe
case trader
05-28-2007 17:21:02
 Re: 2290 Power shift in reply to Joe Prince, 05-27-2007 20:04:16
i guess my first question is did you have the valve body apart?maybe got a spool in backwards? could you have the put the body together wrong between c2 an c3 i always say easy stuff first i put a piston in backwards in a 1370 c2 like to drove me mad.
Joe Prince
05-29-2007 20:15:38
 Re: 2290 Power shift in reply to case trader, 05-28-2007 17:21:02
I spoke to a man with Case at the Sherman TX. He told me to CK the ball and the spring on the back side of the valve. I looked and it was missing. I did not realize it had a CK alve that went side to side. I have the parts on order and will up date when I have the parts.
Thanks Joe
