1200 D.B. PTO clutch stuck
JnL in KY
05-28-2007 15:43:05
Ihave a problem the pto clutch stuck engaged ran a baler behind it and ran 300 bales and it would not dissengage during or after any ideas?????
seantn
05-28-2007 19:47:00
 Re: 1200 D.B. PTO clutch stuck in reply to JnL in KY, 05-28-2007 15:43:05
Did the tractor sit up for a long time? Or did this happen while the tractor was being used? If it sat up a long time the clutch may be bonded to the pressure plate. Just using it may break it loose. If it happened while using it, check free play, linkages etc. If this does not fix it, you may have to start opening her up and look for a bad throw out bearing, or hopefully a pin has fallen out somewhere in the linkage.
This happened to mine one time. You do not have to split this tractor to check or replace the clutch. Remove the fuel tank, steering box and transmission cover. Then you have access to the clutch. good luck!! seantn
