2090 weak hyd.'s
case trader
05-31-2007 17:19:41
2090 worked fine till my remotes got weak, power shift works fine pto lift ok, at a idle light is off, loader goes up, as soon as you rev it light cooms on loader stops almost like oil is bypassing at higher rpm ,dealer says pump is out seems like it happened to fast checked reg. at filters and at screen filters ok didn't check any press. any thoughts.
dwag
06-01-2007 10:49:31
 Re: 2090 weak hyd.'s in reply to case trader, 05-31-2007 17:19:41
Dissamble the compensator and clean. There is a small allen head plug between the 2 spools that has a SMALL orifice that easily plugs.You have to remove the allen plug on the outside of hsg to get to bleed off plug.(the one with the orifice)
case trader
06-01-2007 14:35:02
 Re: 2090 weak hyd.'s in reply to dwag, 06-01-2007 10:49:31
i changed out compensater no help, stuck on differant pump seems ok, i'll take this one apart seems like something just broke really odd.
DKase
06-01-2007 05:28:06
You need to check the charge pump pressure. The light on is an indication that there is not enough oil getting to the piston pump. Remove the light sending unit from the line feeding the piston pump and check the pressure there. Spec calls for 15 psi. If less, there is a suction screen, filter, or charge pump problem. If OK and pressure at the remotes is still low there is a piston pump problem. Good Luck. DK
case trader
06-01-2007 07:29:48
 Re: 2090 weak hyd.'s in reply to DKase, 06-01-2007 05:28:06
screen filters ckd. charge pump removed an checked all before coming to me i'll chk. press. guess i'll put on pump an see.
